Unprimed drywall: what treatment before hanging wallpaper?
Hello everyone, this is my first post here so thanks in advance for any reply.
I am hanging wallpaper for the the first time in my home; we have stripped (with a steamer) and replaced wallpaper fine on some walls, but in one of them the underlying paint was way too damaged, and we had to remove it completely.
So here I am, in front of an unprimed drywall: what products do I have to use? I read everywhere that I need priming/painting before hanging wallpaper, but I am slightly confused as I saw that priming is recommended before both painting and hanging wallpaper.
I don't want paint, I just want to hang my wallpaper; so what should I do?
Please enlighten me...
- priming for paint, then painting, then priming for wallpaper, then hang wallpaper?
- priming for wall, then hang wallpaper?
- priming for paint, then paint, then hang wallpaper?
Welcome to the forums!
I like to see an oil base primer applied and then the sizing [wallpaper primer] That will give you a good chance of being able to remove the paper at a later date while still retaining your sanity.
mitch17,
can't do, it's the wife who decided for it
that, and the smile on my daughter's face when she saw the Disney wallpaper made it worth.
How do you quote other messages here? I can't see an obvious "quote" button anywhere.
There is a little cloud like icon on the right of the top line on the quick reply box - click on it to post quotes.
The oil base primer is to adequately seal the drywall so the wallpaper paste won't suck thru and bond the wallpaper directly to the drywall. Failure to seal the drywall means that you'll have a hard time stripping the paper and will likely damage the drywall during the removal process.
I've only helped hang paper a few times although I've rolled on a lot of sizing. I don't know exactly what it does
but it's recommended as part of the wallpaper prep process.
