Drywall meets tile
Old 01-05-14, 10:00 PM
Drywall meets tile
I had the shower re-modeled last year, and just recently put up new drywall. there's a large crack between the the two on one wall. i had an issue getting it past some concrete backer.
What's the best way to approach filling and finishing this area?
Old 01-06-14, 04:16 AM
Received 759 Upvotes on 664 Posts
Welcome to the forums!
I'd sand the fresh j/c smooth and then flat tape the edge up to the tile. Once the tape is finished, caulk where the tape/drywall meets the tile.
Old 01-06-14, 06:35 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I am assuming there is framing behind the sheetrock. Without it it will crack forever as the humidity changes in te room.
Old 01-06-14, 07:10 AM
Thanks! Glad to be here!
I'll give that some thought
Old 01-06-14, 07:16 AM
Unfortunately, the lower half of the wall doesn't have a stud on the outside edge.
This is my first go at dyrwall, and that was something I didn't notice when putting it up. I slid a beam behind the lower wall before installing the top half, but it's not exactly secure. I was hoping to avoid having any vertical seams, but maybe I should cut back to the nearest stud and redo this area?
Old 01-06-14, 08:16 AM
chandler's Avatar
If you have the option, at this stage, I would support this sheetrock and repair as Marksr indicated. You'll never second guess yourself
