Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Load bearing wall??? Can I take this down? W/ PICTURES.
Old 01-14-14, 09:29 PM
mattdwagner's Avatar
Smile Load bearing wall??? Can I take this down? W/ PICTURES.
I have a closet between my living room and kitchen. Any reason that you see why I couldn't take this down? I want to take it back to the side of the kitchen counter and then build a door flush to access the water heater. Thanks.
Old 01-15-14, 03:21 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
What a funky place/design for a closet. Not being on site, we always recommend the services of a structural engineer to make determinations. With that disclaimer, it appears this closet has load bearing properties. There appears to be a beam type soffit that ends with the closet and needs vertical support.
Others will be along shortly to give further info, but plan on the engineer to give final blessings.
Old 01-16-14, 10:56 AM
Thanks for the reply Chandler. When you say "beam" are you referring to the one in the last picture that protrudes from the closet from the left?
Old 01-16-14, 01:16 PM
chandler's Avatar
Actually I missed the stair landing. So yes, the entire square is load bearing for the landing corners. That's why the closet exists.
Old 01-16-14, 10:35 PM
I see what you mean now, thanks Chandler.
