Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Jet Black Floor Joists with Creote-like substance?
Old 01-22-14, 08:41 AM
R
We live in a 2-story Georgian (w/ basement) built in the early 1950s.
We recently discovered a busted drain pipe running thru an interior soffit in our Kitchen. The plumber suggested it was a longstanding problem (many years) even though we just started noticing any evidence of the problem (water leaking into the kitchen thru the wall/soffit).
When the plumber opened up the soffit to replace the pipe we noticed that the underside of the floor above the kitchen and the floor joists were jet black - almost if they had been sprayed with something.
At first, from a distance, we also thought there was a significant amount of black mold, however, upon looking closer, it looked more like the creosote buildup you might find in a chimney. In some sections, it looked almost like it was 1/2 inch to 1 inch thick.
The plumber thought it might be insulation sprayed with some sort of black tar.
Any thoughts on what it could be? Harmful?
(I apologize for not having photos to share at the moment)
Old 01-22-14, 09:51 AM
Received 757 Upvotes on 662 Posts
Welcome to the forums!
It's been 40 yrs or so but I have crawled under old farm houses and sprayed the joists and subfloor with creosote. Not something I'd want to do again but I was young [maybe dumb] and hungry back then.
Just reread your post, is the majority of it thick? or just in spots? Creosote goes on like a stain.
pics would be nice - http://www.doityourself.com/forum/el...-pictures.html
