Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Fix with drywall compound or tear out drywall?
Old 01-29-14, 02:10 PM
A
Got done getting wall nice and even for tile to go onto take final measurements and notice walls not even with fireplace
Took measurements before tearing down mantel and the wall was level but didn't measure for wall to fireplace since mantel was in the way. Here is a pic looking straight down less than a 1/4 inch gap
Should I add drywall compound or tear down drywall and add new one. The only thing is the wall is still level by itself it seems like the fireplace whoever installed it didn't install properly andits a couple degrees off. Any suggestions?
Old 01-29-14, 02:21 PM
bigfred's Avatar
Don't know if I understand the problem. Apparently you are going to tile a wall that has a fireplace surround that is not square with the wall. If that's the case I would lay the tile square with the wall, and at the fireplace either just caulk the space between the last tile and the fireplace surround, or put some wood trim around the fireplace surround to cover the joint. I'd caulk it first and see if it looked okay, and if not, cover the joint with molding.
Old 01-29-14, 03:09 PM
A
You hit the problem right on the nose. Unfortunately the tile I was planning to use is 12x24 and was planning to overhang it onto the surround.Might have to change my plan on tile to use if I do anything with the wall.
Old 01-29-14, 07:38 PM
czizzi's Avatar
Of the issue is just a little bow in the wall, then adjust the size of the trowel you are using or back-butter the tiles (along with the walls) to add enough mortar that you can still maintain contact but float over the imperfection in the wall.
Old 01-29-14, 07:53 PM
A
Was planning to back butter already and doing a 1/4 trowel wall can fit only 1 12x24 on each side of the fireplace horizontally, Might be better to do it vertically so the bow can be maintained only on one tile.
Thoughts?
Old 01-30-14, 06:32 AM
bigfred's Avatar
If the issue is a bow in the wall, I would probably go ahead and mortar it level before starting the tiling.
