foam board on ceiling above sheetrock
Old 02-17-14, 07:38 AM
R
I'm adding a little bumpout to my house. It will be a nursery for a couple years before it becomes an office or storage.
There isn't going to be a lot of room in the ceiling for insulation and I can't afford spray foam right now.
I was thinking of putting up either half inch pink foam board or the foil faced yellow urethane foam on the joist. I would start with the outside side of the of the space, where the roof joists meet the outside wall. Here there is very little room at all for insulation. Just a few inches. I was thinking of putting great stuff on top of the foam board so it fills in to the foam air baffle (at the very narrowest side) below the roof sheeting.
I might put a 1 inch layer of great stuff above the rest of the ceiling by doing only a small section of foam board at a time. Then I would fill in unfaced fiberglass above that. Sheetrock would go below the foam board.
Does this sound like a workable idea? Would there be a condensation concern?
Thanks to anyone who can help.
Old 02-18-14, 08:25 AM
P
Temporarily Suspended
The foam board might be okay. I don't know about the great stuff. I'm not a fan, of it.
Old 02-18-14, 09:30 AM
C
Received 1 Upvote on 1 Post
Why not cut foam to fit between the ceil. joists and place them just above your bottom edge and foam seal the edges with the great stuff.
Great stuff in a can in designed more for gaps rather than surface application. If you want to get a small spray kit of 2 part spray foam you can find those on line or probably get through an insulation contractor.
