how do i put a fire break in with foam insulation already on walls?
Received 0 Votes
hey guys,
i already put rigid foam and framed the exterior walls of my basement, what i need to know is as far as a fire break is concerned, can i just butt 2x4 boards up against the foam or do i need to cut slots into the foam to go all the way out to the foundation?
Temporarily Suspended
Received 0 Votes
As long as it's flush with the studs, it should be fine.
Received 0 Votes
If the foam is combustable, doesn't just having the 2x4s butted up against and not through the foam mean that if a fire starts the foam would melt and a hole would open up behind the 2x4s?
Received 0 Votes
If you put the fire block against the wall, wouldn't that leave the same space on the front side of it?
I don't think that matters as far as a draft stop is concerned. If the top plate of your wall is still accessible, cap it between the joists with 1/2" plywood or 1/2" drywall that is about 4 1/2" wide so that it covers the top edge of the foam. Or you could use cans of fire rated foam.
I don't think it's an issue, however.
Previous Thread
Next Thread
