base of walls leaking
Old 03-31-14, 04:27 PM
B
i have a room built on top of concrete and every time it rains water leaks in the base of the walls how can i stop the leaking?
Old 03-31-14, 05:02 PM
P
Temporarily Suspended
We need more info than that. Is there a high water table? Is the pitch towards the house? Are all the walls leaking? Is the room a converted garage? Can you post some pics from the outside?
Old 03-31-14, 05:14 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
If this is a slab foundation, it sounds like the grade around the foundation is too high. Water should run away from a house. And the soil outside can't be higher than the top of the slab.
Old 04-01-14, 04:32 AM
Received 754 Upvotes on 659 Posts
Welcome to the forums!
Some pics of the outside of the house might be helpful - http://www.doityourself.com/forum/el...-pictures.html
