Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Replacing Drywall - Any tricks / tips?
Old 04-17-14, 08:01 PM
So I'm doing my kitchen (approx 24' x 12' room) and for several reasons, I think I need to gut it to the studs and hang all new sheetrock. I'm putting in a dozen recessed lights, the existing ceiling is textured, moving plumbing, and the original job wasn't the best to begin with. So, are there any tips for getting down to clean studs quick? Other than just ripping it all off and then backing out all the screws one by one?
Many thanks in advance!
Old 04-17-14, 11:10 PM
T
Received 41 Upvotes on 34 Posts
If you hit the screws with a hammer they usually break off at the surface. You are sure to hit some of the broken screws wih the new screws when you install new wall board.
Old 04-18-14, 03:44 AM
Received 759 Upvotes on 664 Posts
It's best to drape off the openings to the adjoining rooms, the dust can and will go everywhere
Old 04-26-14, 04:45 AM
Thanks guys. My wife already reminded me about the dust and I don't think she'll let me forget that one! Good idea on the screws, I'll certainly use that one.
Old 04-26-14, 05:22 AM
B
Received 47 Upvotes on 43 Posts
I try to remove as many screws as possible, given that we now use a drill for that task and only break off those that will not cooperate. A small window fan blowing out (remove the screen) will create a negative pressure in that room to ensure the dust stays or exits via the fan. The plastic you put up will never be perfect.
Be sure those recessed lights are air sealed and IC rated if space above is an attic. Good choice even if just cavities exposed to an exterior wall. Consider Roxul for new insulation and caulk or foam all penetrations. Sheet metal or other air stop for any larger openings.
If you have 2x4 walls then consider adding an inch of rigid insulation over the inside of the exterior wall.
Be sure your kitchen exhaust fan is vented to the outside, especially if you have a gas appliance and select a quiet one. If you are going with a huge range and oversized range hood, then there are separate requirements for make-up air.
Check code requirements for all new electrical and plumbing.
Great time to get started and welcome to the forum.
Bud
Old 04-28-14, 06:04 AM
Thanks bud, all good tips. I'll make good use of them all.
