Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Removing wall between living room and porch?
Old 06-07-14, 01:08 PM
G
Hi,
I'm hoping for some help removing the door and wall between my living room and four season porch.
Here's how it looks:
Elevation Section:
https://drive.google.com/file/d/0B-9...it?usp=sharing
Floor Plan:
My first question is whether the wall is a load bearing wall. My immediate reaction is that it must be, but looking at the elevation, it looks like there might already be a header above the wall. If that's the case, I don't need to put a header beam across the wall. Any thoughts?
Old 06-07-14, 03:35 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
It is load bearing. Any beam will need to span continuously from wall to wall with adequate support at each end. Most likely your beam only spans the door space.
