Attached garage finishing
Old 06-28-14, 08:41 AM
G
All,
I am remodeling my 2 stall attached garage. The garage has 2 different garage doors that are 9x7. There are also 2 different walls that abut the house. I plan on using Sheetrock for finishing. I have a few questions...
1. What thickness of rock should I use?
2. How should I insulate and should I use vapor barrier? The 2 walls that abut the house have insulation in the walls...I thought about replacing it all, good or bad idea?
3. Am I supposed 2seal the rock at the bottom where it meets the concrete?
Thanks for the help
Greg
Old 06-28-14, 08:50 AM
Received 398 Votes on 354 Posts
If you remove whatever wall covering is currently on the house side walls - it needs to be replaced with 5/8" fire rock to meet code. 5/8" is best on the ceiling also. You can use 1/2" drywall on the rest, your choice.
A lot depends on the condition and R rating of the current insulation. The vapor barrier goes on the house side of the common wall. You don't want a vapor barrier on both sides of a wall!
It's best to stop the drywall short of the concrete floor so it won't wick up any moisture that gets spilled or when washing out the floor.
Old 06-28-14, 09:10 AM
G
The 2 common walls do not currently have a vapor barrier on either side. Is it ok to put it on the garage side?
Old 06-28-14, 02:20 PM
I don't know Doesn't the insulation have a paper face on the interior side?
Old 06-28-14, 06:59 PM
G
Yes, the side that faces the house has a paper face
Old 06-29-14, 03:21 AM
While a plastic vapor barrier is better, paper facing was used for yrs as a vapor barrier. Not my area of expertise but you aren't supposed to have 2 vapor barriers, either one or the other.
