Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Replacing drywall, but not sure what to do where it meets the counter.
Old 06-28-14, 09:15 AM
A
So I have gotten pretty much the whole bathroom re-drywalled, but I have a sink counter that goes from wall to wall and the drywall goes behind it. The old drywall has wallpaper that we are replacing with textured paint.
Here is what it looks like right now:
I tried peeling off the wallpaper before, and it pulls the green anti-mold sheet away as well and leaves a nasty rough cardboard look that wouldn't be very paintable.
Obviously the correct way to do it would be remove the counter, and change the entirety of the drywall, but that's not gonna happen.
Any tips on this?
Old 06-28-14, 09:35 AM
Received 1 Upvote on 1 Post
Making it a whole lot harder on yourself by not removing that whole vanity.
Under direst if I had to do I'd remove the rest of that drywall with an oscillating saw.
Big mistake having any type of texture on a bathroom or kitchen wall.
Makes it near imposable to clean and a simple repair becomes a big job to get it to match.
Old 06-28-14, 09:59 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I would release the vanity from the wall by unscrewing it, remove the tailpiece or ptrap, and move the vanity from the wall slightly to give access to the sheetrock below the splash. Then pull or cut away the sheetrock at least 3/4" below the splash. Replace sheetrock and put vanity back in place. Post a picture of the plumbing undermthe vanity if you can.
Old 06-28-14, 10:08 AM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
If you can't or won't remove the vanity i would suggest you leave at least 2" of drywall around the vanity and strip that wallpaper off whatever is left. Put in some backing and drywall up to it. It will be like a butt joint all the way around it. If you expose the paper surface of the drywall, hit it with oil primer before you tape.
Old 06-28-14, 12:04 PM
A
There is no moving the counter out from the wall, its 60" long, and the room is 60" wide. Best thing would be moving it out from the back wall about 10" before it hits the door way. But that wouldn't help much.
I don't see any screws for the counter-top, it must be glued on. So popping that off would most likely ruin the particle board, so I can't really get behind the splash guards like I would want to.
Old 06-28-14, 12:38 PM
chandler's Avatar
Then do as XSleeper says and make a joint high enough on the wall to where you can smooth out the drywall compound and make it disappear.
Old 06-28-14, 02:28 PM
Received 754 Upvotes on 659 Posts
Very important! the primer seals the exposed gypsum and keeps if from deteriorating when the water in latex paint or joint compound is applied to it. The only water based primer that will work is Zinnser's Gardz, most any oil primer would be fine.
