budget - covering up window frames
Hi all,
just a question for some feed back
i m currently doin some work on my house and tryin to cut some cost and need some help if possible
Im removing a window and was given a quotation for extration of the window and the frame
has any1 cut corners on this by not remove the frame and either cementing it or making a box to cover it up?
lookin for some feed back on this if possible
thanks guys
Cheers
thanks guys
Cheers
Welcome to the forums!
Is this a masonry wall? pics might be helpful - http://www.doityourself.com/forum/el...-pictures.html
You should be able to lift up the sliding doors and then pop them out of the track. You'll see screws that hold the frame in place. There may also be caulking along the perimeter that should be cut. Once the door frame is removed, frame up a stud wall and cover it to match the existing walls.
