Hole in shower tile wall
Old 09-20-14, 10:15 AM
X
My son knocked the soap dish off my shower wall and now I have a hole in the shower tile wall. Any idea how to fix this? It looks like there is some insulation behind the wall.
Old 09-20-14, 10:56 AM
czizzi's Avatar
May be a fatal exposure - Was there drywall behind the tile? Most likely, the caulking failed, leading to moisture behind the soap dish which wet the drywall causing failure. I think you can chance a repair, but recommendations would not come with any guaranty's. Other sections of the drywall were also moistened when the exposure happened. My gut tells me that the whole wall is weak as a result. If you grab the tile left around the hole, can you wiggle it and the whole wall at the same time?
Old 09-20-14, 01:08 PM
Received 754 Upvotes on 659 Posts
What is on the other side of that wall? another room? or is it an exterior wall?
btw - welcome to the forums!
