Drywall layout for odd ceiling height
Old 10-18-14, 08:26 AM
D
I'm remodeling a bathroom in a 1926 house and will be doing a plaster veneer. Blue board seems to be the recommended substrate. It's available here in 4x8 sheets.
The walls are 100 inches tall, which means two sheets butted side by side leaves a gap of 4 inches. Two walls are also 8 feet 3 inches long, again leaving a gap of 3 inches.
For the horizontal gap, I can buy more sheets and create a single seam in the wall, although it creates quite a bit of waste. What do I for the height problem? The baseboard will be 3.25 inches high so I can't cover up the gap at the bottom.
How should the drywall for the walls be laid out?
Old 10-18-14, 10:07 AM
Received 1,231 Upvotes on 1,179 Posts
Drywall is available in 54" wide sheets - blueboard is not?
Old 10-18-14, 01:17 PM
Received 786 Upvotes on 689 Posts
Where are you buying your blueboard? I'm not overly familiar with blueboard but I know it also comes in 12' sheets, not sure about 54" wide. Check with your local drywall supply house, they'll have a better selection than a big box store. I don't think the number of joints are as critical when applying plaster veneer as it will hide a lot - but the plasterer might disagree with me
Old 10-18-14, 08:04 PM
Received 1 Upvote on 1 Post
And why in the world are you going over it with plaster?
It's just not needed, last thing I'd want in a wet, earthquake prone area.
Old 10-18-14, 11:29 PM
D
Blueboard is not available in 54 inch wide sheets at my drywall supplier in a major metro area.
I'm doing plaster veneer because I want the look to match the rest of the house and it provides a harder finished surface than drywall. The rest of the house was plastered in 1926 and has what is called an "old world" finish.
