Access Panel Through Two Walls
Hello -
I'm a newbie to DIY Home Improvement, so please bear with me. I need to cut an access panel through two walls in order to reach through one side of the wall to the other side where my washer/dryer sits. I need to do this so that I can appropriately connect my dryer hose from the dryer to the outlet.
I plan on installing a plastic access panel, such as this (Access Doors & Panels | Flush Access Doors | Plastic Access Door - 8 x 8 | B204666 - GlobalIndustrial.com).
I understand how one cuts and installs an access panel through one sheet of drywall, and I will first install the plastic access door through drywall sheet #1. For drywall sheet #2 (the wall immediately adjacent to the washer dryer), I assume I will do the same except I would be installing the access door on inside of the drywall (rather than the outside as for sheet #1).
Any tips? My guess is that there will be both plumbing and wiring between the drywall sheets, given the washer dryer. I assume I should shut off electricity first?
Thank you!
Thank you!
Why do you need the access holes? How will they help in connecting the dryer hose? Can't you connect the hose and slide the dryer back, compressing the flexible hose?
As appliance repair person I run into this all the time. Easiest if there is room is to install dryer first, Connect vent and slide dryer back, If you have 2 people have one person slide dryer back and the other line up vent hose. Another trick is to tie a rope,(string) to vent hose. run it over dryer back and use this to line up vent hose.
