Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Temporary Wall - Protecting the Ceiling.
Old 11-26-14, 07:44 PM
P
Hi,
I will be opening part of my kitchen/dinning wall (80"). I will a need temporary wall on each side until I add the new support beam above the 80" opening.
1. Any ideas how I can setup that temporary wall so I do not damage the stipple ceiling ?
The temporary wall will be an horizontal 2x4 at the ceiling where some vertical 2x4 will hold the 2x4 at the ceiling stable.
My first idea, so I do not damage the ceiling, is to put small bubble wrapping in between the stipple ceiling and the horizontal 2x4.
Any feedback and ideas are welcome... appreciated...
Thanks,
M.B.
Old 11-26-14, 09:17 PM
Received 1 Upvote on 1 Post
Good luck not damaging that ceiling. Your going to be doing some drywall repair anyway.
Bubble wraps not going to allow the 2 X to make direct contact with the drywall and will not fully support it, also likely the walls not going to stay in place.
Old 11-26-14, 10:07 PM
Handyone's Avatar
You can place a 2 x 6 or 2 x 8 at top of temporary walls. Vertical members can still be 2 x 4's, the 2 x 6 or 8 will spread the load a little more evenly. Whenever removing a wall it's essential to install temporary walls. Depending on your situation, a temporary wall may not immediately need to accept great loads, it's a safeguard. It could compress the ceiling texture, but not likely.
Old 11-27-14, 03:12 AM
Received 753 Upvotes on 658 Posts
You could also use a wide strip of plywood to lessen the stress on the ceiling although I would expect to do minor touch up to that area of the ceiling once you are done.
Old 12-12-14, 02:41 PM
P
Many thanks... good idea, making it wider than a 2x4... to spread the load a little better.
Another question if I may:
In order to NOT damage the ceiling... I'm assuming it will better if I have someone hold the 2x8 at the ceiling while I am putting the vertical members ?
The reason I am saying the above, is that I am thinking that I will damage the ceiling if I create my temporary wall (nailed/screwed) first flat on the floor and then raise it up, tight to the ceiling.
Does it make sense ? Please advice. Thanks, M.B.
Old 12-12-14, 02:51 PM
T
Received 41 Upvotes on 34 Posts
As I recall geometry, you can't build the wall on the floor and raise into place. This is especially true if you do not want to damage the lid.
Old 12-12-14, 03:10 PM
Handyone's Avatar
tightcoat said it all. Yes, you need to build the wall in place. If you cut any vertical members a little short, shim them up. Make the wall tight to ceiling.
You will be toenailing all screws.
Old 12-12-14, 05:33 PM
P
Many thanks for the advice..
