Where to buy 5/8 Sheetrock Panel
Old 12-15-14, 12:02 PM
B
I have a small repair job i need to do. About 12" x 3". My drywall is 5/8". The problem I have is that I can't find a place that sells 5/8 drywall in a panel small enough to get in my car. Anyone have any recommendations?
Old 12-15-14, 12:21 PM
ray2047's Avatar
Try a mom and pop lumber yard and ask if they have any broken sheets.
Old 12-15-14, 12:29 PM
A
Received 73 Upvotes on 66 Posts
Or a Habitat Restore if you have any in your area.
Old 12-15-14, 01:32 PM
Received 757 Upvotes on 662 Posts
You might also check some construction sites, they always have scrap drywall when the building is at that stage of construction. While using 5/8" would be easiest, you could use 1/2" and either shim it out or build it up with mud .... since it's such a small repair.
Old 12-15-14, 01:36 PM
B
I may just build it up since it'll likely end up behind a tile back splash anyway.
Old 12-15-14, 01:58 PM
XSleeper's Avatar
Received 1,747 Upvotes on 1,571 Posts
Menards sells scraps. They should have something for a buck or two.
