Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Durock vs Hardiebacker: spelling alert
Old 12-18-14, 10:08 PM
B
Received 1 Upvote on 1 Post
"durock vs hardiebacker": 1 result
"durock vs hardibacker": 5,530 results
I have photographic evidence that's it's spelled "Hardiebacker." The incorrect spelling is more common even on this forum. I'm glad I noticed it. I'll have to search for the incorrect spelling to get more info.
Old 12-19-14, 04:41 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You are 100% correct, and I am as guilty as any for mis spelling it. It is Hardiebacker, and it is imprinted in 3" letters on each sheet! Looks like Google wants us to use the other spelling, however.
Old 12-19-14, 08:53 AM
B
Anyway, Durock is a little safer according to the MSDS and people are saying it's more water resistant and it's easier to countersink screw heads using normal screws without pre-drilling so that's what I'm getting.
Old 12-19-14, 11:35 AM
czizzi's Avatar
If you just search for "Hardibacker" my google shows that it is showing results for "Hardiebacker" automatically. If you want to search for Hardi... you have to tell it to.
Both Hardiebacker and Durock have specific screws that are to be used for installation. They are found in the tile department at box stores. You can not use regular screw (drywall, deck screws, etc.) for the installation. The CBU specific screws are designed with a wider, flatter head that has small striations on the underside of the head to carve out some of the CBU material so that they sit flush. Regular screw heads will blow out Durock and not hold well, and not set at at all into hardie.
