Weird ceiling. Any idea what this is?
Old 12-28-14, 01:09 PM
B
Older house. Moved in about two months ago. Just noticed this on the ceiling. It's a weird pattern
Old 12-28-14, 01:13 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! Looks to be a poor attempt at skim coating. Marksr will chime in here shortly with his ideas.
Old 12-28-14, 06:29 PM
Received 1,197 Upvotes on 1,152 Posts
Larry's guess is the same as mine.
Do you know anything about the ceiling? Is it different than the other rooms in the house? What's above this room?
Old 12-28-14, 09:04 PM
T
Received 41 Upvotes on 34 Posts
About what are th dimensions of the areas between the lines? It looks like the lines are depressions and the areas between the lines are like pillows. Is this right?
Old 12-29-14, 02:07 AM
B
This is happening to two ceilings. One has a bedroom above it (the picture), one has the attic above it which is not as bad. Yes, it looks like pillows.
Old 12-29-14, 03:46 AM
Received 754 Upvotes on 659 Posts
How old is the house? when did this first appear? is there any give in the ceiling? have you put a straightedge along the ceiling in various places to determine how much it has sagged? [assuming it wasn't a poor skim coat job]
