Gaps between drywall panels
Old 02-10-15, 03:45 AM
T
I'm not really sure what happened here. Maybe we were going too fast, but after screwing down several drywall panels, we noticed a couple spots in the corners of the room where the upper drywall panel doesn't even touch the ceiling drywall panel. I'm concerned about the gap. I haven't measured it, but in one place it looks to be as big as about 1/4 - 1/2".
Should I just not worry about it and tape and float it? Or is there another technique? I was thinking about filling the gap with drywall joint compound or even silicone, and then waiting for that to dry before doing the tape and float.
Old 02-10-15, 04:15 AM
C
Received 1 Upvote on 1 Post
Yes, prefill the gaps. You can use regular compound but would be better to use one of the setting type powder compounds. You can get them in various timed setting mixes, perhaps the 45 min. material would be good for the job. Big box stores have them.
Received 753 Upvotes on 658 Posts
It's common to fill those types of gaps with a setting compound like Durabond, regular ready mix j/c dries too slow and will crack if applied too thick. You don't need to fill the gap flush with the drywall, just enough so the mud you use when taping won't fall out.
Old 02-10-15, 05:54 AM
Received 1,197 Upvotes on 1,152 Posts
One more vote for filling with setting compound.
Old 02-10-15, 05:55 AM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
I agree with the guys above. I'll usually mix up a pan of the 20 minute setting compound and fill those gaps with that. Generally it will be ready to tape within an hour or two. Its always good to have a bag of it on hand... and I'll fill any gap that's +1/8.
Old 02-13-15, 05:30 AM
T
Hey guys. Thanks for the suggestions. I did try prefilling the gaps with some drywall compound before eventually taping and floating. It's been tedious and time consuming, but the prefilling technique has worked out well so far and it looks great. On the portions we finished, you can't even tell there were large gaps that existed before.
Old 02-13-15, 06:27 AM
Using a setting compound to prefill the gaps is quicker/easier. It dries faster and is less likely to sag or fall out as it dries than regular j/c.
Old 02-15-15, 09:24 PM
T
Yeah you guys are right. I switched from the joint compound to a setting compound and it like marksr said. Much faster drying. Seems like the setting compound dries harder too or maybe that's just my imagination. I wish I didn't fill in the first ones I did with the joint compound.
Old 02-15-15, 09:46 PM
Handyone's Avatar
Setting type (called hot mud), does dry harder. You want to use the regular mud when finishing. The hot mud is hard to sand.
Old 02-16-15, 04:57 AM
Ya, I almost always use durabond for the 1st coat or 2 but always use regular j/c for the final coat .... I don't like working harder than I need to
Old 02-16-15, 10:50 AM
T
Ahh. I thought the setting compound (hot mud) was harder than the joint compound, but I probably was just more liberal in applying to the gaps. Whatever the case, it's been working pretty good so far. After applying the dura bond to the gaps (btw, thanks for the suggestion mark) I still have a little bit more to go to completely fill the gap and I think I'm close enough to just finish it off with some standard tape and float with joint compound. Thanks again everyone. The results are really good and I can't even tell that there were such bad gaps before.
Old 02-16-15, 12:46 PM
I don't like to sand durabond [not fond of sanding anything ] so I try to never apply too much and when you are prefilling gaps it doesn't have to be smooth or level - you just need a base to hold the j/c when you tape. Same sanding scenario applies to the rest of the drywall finishing - it's easier to come back and add more mud than sand off a bunch of excess.
