Rendering
Old 03-29-01, 01:13 AM
Talking
I want to render a wall at home but I cannot get a smooth finish. Would anyone have any advice about rendering with redi-mix concrete and how to get it smooth?
There are wooden, steel, aluminium, and plastic trows, is one better than the other, have tried wood with no success?
Old 03-30-01, 10:09 PM
Wood float = rough finish. Magnesium float = semi smooth finish. Steel Trowel = smooth finish. Purchase a Marshalltown pre-broke-in steel trowel (avoids hand lapping in over smooth concrete).
A normal process might be:
> Set grouds (guide boards for the rod. [In flat work a rod is called a screed board and grouds would be the form boards]. [different plains = different names].
>Apply mortar,(scratch coat), then scratch.
>Next day, (no accelerator used), dampen, apply brown coat, rod to a flat true plain. (Pull grouds and fill if required)
>Wait.
>(If necessary) when harder but still plastic darby highs. [A darby is a large wood float 3 feet or more in length]. ***[When grouds are omitted darby after application].
>When thumb print hard float with a magnesium float followed by an 18" steel trowel. The trowel is held flat to the surface (no lifting of edge in the direction of travel). Overlap strokes.
>Wait.
>Same trowel: do again (more pressure, lift edge 5-10 degrees in the direction of travel).
>Wait.
>Smaller trowel 3rd time (more pressure, lift edge 5-10 degrees in the direction of travel). A characteristic ringing sound should be heard.
