Can these walls be fully removed
Old 05-05-15, 03:01 PM
R
I am removing two wall and wondered if I had to keep the point of intersection (there is no metal beam there or any main beam). The point of connection has 3 2X4 wood beams stuck in a squared shaped (as in the picture).
Old 05-05-15, 03:07 PM
Norm201's Avatar
Received 674 Upvotes on 597 Posts
That's a typical corner junction for two walls at right angles. Are you sure this is not a load bearing area?
Old 05-05-15, 03:12 PM
R
There is no floor on top only an isolated attic. Its a split level, I've seen many break these walls to make it an open concept style...just wondering if I have to keep these 3 beams or if they can be removed.
Old 05-05-15, 03:20 PM
K
Received 4 Upvotes on 4 Posts
The three studs do not indicate a load bearing wall, it is a normal way to address the corners of walls. However, considering you have two walls going in different directions, it is quite likely that one or the other is load bearing. Does your attic have trusses or is it stick framed with rafters and ceiling joists? If the latter, check to see if the joists run perpendicular to either of these walls, and if they have a lap joint over them. If so, it is load bearing.
Old 05-05-15, 04:25 PM
R
Its stick framed with rafters and ceiling joists, I'll have to check to make sure none are load bearing. From what I've read split level load bearing walls are exterior walls only...
Old 05-05-15, 04:28 PM
K
It is very unusual for there to be no load bearing interior walls with a rafter and ceiling joist system unless your house is less than 16' wide.
Old 05-05-15, 04:32 PM
R
The house has 2 roofs perpendicular to one another. Its not one huge roof.
[ATTACH=CONFIG]50185[/ATTACH]
Old 05-05-15, 04:45 PM
K
As long as the ceiling joists are continuous, the walls *should* be ok to remove. If they are joined over a wall, it or some other support must stay in place.
Old 05-05-15, 04:52 PM
R
OK thanks for your help, I'll make sure by checking the attic first, might also bring a friend of mine over to take a look, his an architect might be helpful
Old 05-06-15, 06:26 AM
R
By the way is this info correct: Load Bearing vs. Non-Load Bearing Walls
Old 05-06-15, 05:31 PM
K
Yes, that info is generally correct. But note that one is a trussed roof and one is not. There can be situations where a trussed roof needs a support wall in the middle, but it is uncommon.
Old 05-07-15, 05:59 AM
R
My house inspector sent me a message stating the following:
"No bearing walls in gable end houses. Your roof is self supporting trusses. Load I picked up by exterior walls."
I have a friend of mine who is in construction pass by my place to confirm this.
If so I assume I'll be able to remove completely both walls including the corner where the 2 walls collide.
Old 05-07-15, 07:52 AM
K
If you do in fact have trusses, the walls should be safe to remove without issue.
The "no bearing walls in gable end houses" comment is BS though. That is a way too general statement to make.
