Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Shaved ceiling doesn't look smooth after installing lights
Old 06-03-15, 07:48 AM
B
Hi all,
Recently I embarked on shaving the popcorn ceiling in my hallway of the condo I live in. Underneath was concrete not your typical drywall. Anyways, to make things easier I dropped my ceiling lights so I can flatten out the ceiling and paint under them but left them connected so I can use the light. After applying two coats of compound, sanding smooth, and using behr's primer and paint in one I thought my ceiling looked pretty good. When I reinstalled the light fixtures flushed to the ceiling I was horrified that I could see all the imperfections..
Pics are attached. Not sure if I need to get back on the ladder and start smoothing everything out or if I missed an important step to hide the compound used. Please help, this ceiling has been such a pain.
Old 06-03-15, 08:12 AM
czizzi's Avatar
You have discovered an excellent trick to gauge how well you have applied compound to any repair or seam installation. That being shine a light across the wall at steep angle. It will show all shadows and imperfections. Leave the lights up and concentrate on the imperfections you see. Also, for fresh compound, it is best to separate the primer and the paint and not use an all in one. That may be OK for an over paint, but not fresh compound where you have to seal the joint compound.
Old 06-03-15, 08:25 AM
B
Hi czizzi,
What do you suggest for me at this point? Sand, primer, paint?
Old 06-03-15, 10:16 AM
Received 753 Upvotes on 658 Posts
It's always a good idea to sand the paint before applying more compound but don't expect to be able to sand out all the defects - it's a lot easier to fill in or over the bad spots and then sand, prime and paint.
Old 06-03-15, 10:51 AM
czizzi's Avatar
Now that you have painted it, the ceiling will resist further sanding. Best to try to add and feather additional compound.
