crown molding to accommodate settling
Old 07-14-15, 01:08 PM
Y
I am thinking about installing crown molding throughout my home. My house however does have some settlement issues between the seasons.
I was wondering if I should only nail the crown to the wall joist only and leave the ceiling to give a small gap for movement.
what do you guys think?
Old 07-14-15, 01:14 PM
P
Temporarily Suspended
How old is the house? Crown molding doesn't come cheap.
Old 07-14-15, 01:24 PM
Received 1,197 Upvotes on 1,152 Posts
What are "settlement issues between the seasons?"
Old 07-14-15, 02:38 PM
Received 757 Upvotes on 662 Posts
yes, please elaborate on the settlement issues! also what size crown do you intend to install?
btw - welcome to the forums!
Old 07-14-15, 03:27 PM
P
Received 1,849 Upvotes on 1,655 Posts
While leaving room for settling is common with log homes it is not for all other types of construction. Are you having movement between your walls and ceiling?
Old 07-14-15, 05:05 PM
XSleeper's Avatar
Received 1,747 Upvotes on 1,571 Posts
Crown moulding is a bad idea if your ceilings aren't straight. Also a bad idea if there is known lifting/movement. Most crown moulding should always be nailed to both the wall and ceiling. If you want to avoid nailing to the ceiling I would suggest nailing some backer to the wall first to give you more surface to nail to.
Old 07-14-15, 06:41 PM
F
Does your roof have truss construction rather than rafters? If yes, I would suspect truss uplift instead of settling issues.
