Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Paint bathroom wall after removing old tile?
Old 03-05-16, 08:06 AM
G
I just bought a house and the bathroom has that typical old tile on the bottom half of the walls. My question is what's the easiest way to paint the walls because it will leave behind the old glue from the tile
Old 03-05-16, 08:28 AM
C
Received 288 Upvotes on 238 Posts
The tiles are probably set in a mortar mix. If the tiles were properly installed there will be some sort of cement backer board behind them. If you wish to remove the tiled walls you will have to replace the backer board with sheetrock.
If the tiles were installed directly on sheetrock I doubt if you can get them off without damaging it.
Old 03-05-16, 08:46 AM
Received 754 Upvotes on 659 Posts
If you are going to remove the tile - that needs to be done first. What is the age of the house? Do you know if you have plaster or drywall?
btw - welcome to the forums!
Old 03-06-16, 04:07 AM
czizzi's Avatar
My experience has been that you should plan on replacing what ever is there with new drywall and blend it into the upper half of the existing drywall. Little of any backer will be salvageable if it is put up on drywall. Once the paper on drywall in compromised, the wall loses its integrity and strength. Think of how easy it is to score and snap drywall to install it. Without the paper, the wall will be very weak.
