How to dry drywall
Old 05-26-16, 04:26 AM
How to dry drywall
Hello All,
See photos.
Without tearing a hole in the ceiling, what is the best way I can attempt to dry out this wet drywall ceiling? I had a leak from the washer upstairs that saturated this ceiling. I have had a fan on it for a few days and it seems to be working. I wanted to know if there is a way I could accelerate the drying process. Perhaps heaters?
Old 05-26-16, 05:09 AM
XSleeper's Avatar
Received 670 Votes on 620 Posts
Use a fan........................
Old 05-26-16, 05:19 AM
P
Received 622 Votes on 575 Posts
Yes, set up a fan or space heater blowing on the area as air movement will help carry the moisture away faster. You can also run a dehumidifier or the house's air conditioning to lower the humidity inside the home.
Old 05-26-16, 07:03 AM
Received 318 Votes on 282 Posts
I'd also cut/drill a small hole or two to facilitate the water removal, doesn't have to be a big hole - just an escape route for the water. Generally caulking is enough to seal back small holes in a ceiling like that.
