Remove steel-framed wall corner
I am looking to remove a corner stud where two steel-framed walls meet, re-frame the corner (probably with two 135 degree corners) and re-drywall it. In the diagram with the 90 degree corner, I can only remove the stud that forms the corner; the other two must remain where they are. The second diagram shows what I'm imagining. I was wondering if anyone had ever done this and had tips on how to alter the track and how to frame this corner. Thanks so much.
Never done it but if i had to, a stud would be placed flat at an angle and several sheet metal straps would wrap around the corner and would be screwed to each stud to tie the 3 studs together.
XSleeper
joecaption, your Google image search shows wood framing, which I hadn't considered, but that could work.
You could. Best way would likely be to form the entire corner on a metal brake and screw it to the 2 existing studs.
http://www.usgdesignstudio.com/resou...large_1200.jpg
I like your second drawing with the stud disconfigured along its length. Putting a stud in the middle of the run and strapping as Brant suggested is a good way. Face it, the sheetrock corner may not have much need for fastening once you install paper backed metal corner bead.
