Can you reuse drywall?
Old 11-29-16, 07:11 AM
C
I have a basement that have the top drywall installed already. However, I want to redo the room for sound proofing. So, can I just take the drywall out and reuse it again? The drywall is not finish yet.
Old 11-29-16, 07:26 AM
W
Received 16 Votes on 15 Posts
Drywall
Is it fastened with nails or screws?
Screws would be easiest to remove with minimal damage.
Old 11-29-16, 07:28 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes if in good conditioned. If it is nailed not screwed you can use a gasket hole punch or 1/8" pipe nipple with one end sharpened to a taper to cut around the nails.
Old 11-29-16, 07:47 AM
C
I believed it uses screws. Okay, so when I put it back, do I need to screw at a different location or can I use the existing location to screw it back?
Old 11-29-16, 08:51 AM
ray2047's Avatar
I'd use a different location.
Old 11-29-16, 08:56 AM
Received 229 Votes on 204 Posts
It might not be worth the effort. Loose drywall is easily damaged. Be careful both with taking it down and how you stack it. While I've reused a piece here and there, I'd be leery of rehanging a whole ceiling with 'used' drywall.
Old 11-29-16, 09:32 AM
B
Received 33 Votes on 30 Posts
How long has the drywall been up and what thickness is it? Getting it down will be a 2 man job to be sure it is in good shape.
Bud
Old 11-29-16, 09:41 AM
C
I don't know how long the drywall are but it looks to be pretty good shape. The drywall are going to be used on walls and not ceiling. I'm only redoing the walls for sound proofing.
Old 11-29-16, 09:55 AM
B
If it has been up for several years and especially if it is 3/8" thick then it can have a belly between the joists. Probably not critical if appearance isn't an issue.
Bud
Old 11-29-16, 10:07 AM
Received 93 Votes on 82 Posts
I've never been patient enough to remove it in such a manner it could be re-used.
