replacing bathtub walls
what is the best way to waterseal a bathroom wall tub/shower combo?
i've watched numerous videos and there are different thoughts on the topic..
Not sure who exactly is correct.
i've seen some that suggest putting a plastic liner under the backerboard and others that suggest just coating the backerboard with waterproofing material such as redguard.
if someone could comment on the exact waterproofing material needed i would appreciate it.
thanks
thanks
I've always used 15# roofing felt - cost is around $18 or you can go with a paint on one which costs $50 gal. and will give you enough to do 3 or 4 showers.
