Mounting a projector on the ceiling
I am trying to mount a projector to the basement ceiling. I have found a joist where I want to put it but there is a light nearby. I would like to make sure that there are no wires that I might go through. How can I check? I tried using my stud/wire detector but it is unreliable. Also, the joist end has duct work on one side and is capped by metal on the other. Why?
If there were wires running thru the joists..... they should be up more than two to three inches from the bottom. Use 2" fasteners.
I just re-read your post. If one side is panned and there is a duct on the other side..... there won't be any wires thru the joist.
How do you plan to get wiring to the projector?
Thanks for the answer. The only other concern I have is that there is a small bump exactly where I want to put the projector, don't know what it is so I might drill into it and use an endoscopen to check it out, not sure though. I plan on running them acrOSS the ceiling and down. I would love to tear into it and put a plug on the ceiling but maybe later.
I would use a small screwdriver to "probe" the area. I don't recommend drilling into an unknown.
I use a nice thin 10" screwdriver to probe into an unknown area.
I do the same thing when I'm installing a box in sheetrock.
Much easier to patch a tiny hole than a gaping hole.
I got up and poked the area with a screwdriver. I'm not sure how to proceed, i didn't find anything definitive, there's a joist there but I'm not sure whats really there. Maybe i should dig a bigger hole?
https://imgur.com/dFDg8Lo
If you've confirmed that is a joist (stud) then you are good to go.
What you are trying to eliminate is cutting a hole where there is something shy of the sheetrock like a pipe or duct. Since your bracket will be installed into the joist.... you aren't worried about what is run next to it.
