Wall Marks? Should I get this inspected?
Hello,
I recently purchased a home and just noticed this markings on the wall and I have become a little scared it is something serious. Are markings like this normal?
This interior wall is on the main level of a 2 story home (plus a basement). It sits below the master bathroom, hence my worry. The marking are not wet to the touch but do feel slightly cooler to the touch.
Hello marksr!
The home was built in 1998.
Directly above that wall would be the floor of a hallway. But directly above where I am standing (view point in the photo) is where the bathtub in the master bedroom sits. For reference, I am probably 4-5 feet away from the wall in the photo.
Could be stains from an old leak. As long as you can verify there isn't a leak of some kind and the wall stays dry - the fix would be to coat that area with a stain hiding primer and repaint.
Maybe, but it's hard to say if it is weaker because it's currently wet, had gotten wet previously [and dried out] along with the fact that drywall will have more give between the studs. If you see no change in the wall in a week or two - it's likely fine.
Is it doing something similar on the ceiling? Water will usually soak the ceiling first before it goes down the walls. May very well have been an issue with a previous leak that was fixed and they tried to hide it for the sale of the house with a single coat of a less expensive paint. If it is not growing, is not wet, and shows no signs of an active leak, your can probably hide with a quality paint. Is this an actively used bathroom above the area?
