Removing texture paint
I have a house with drywall but someone has used that texture paint to try to make it look like plaster. Is there an easy way to get this stuff off? Thanks
Received 0 Votes
You could always try to use a spray bottle with warm water and moisten an inconspicuous area and see how the water reacts to the paint. It may soften it up enough so that you can use a scraper to slowly scrape the paint off the walls. That may be the easiest step to try first if you haven't given that a shot yet.
Looking up other techniques on how to remove textured paint returned a lot of labor intensive and messy steps. The techniques are applying a skim coat of drywall mud, sanding the paint, or (gulp) removing the paper layer of the drywall (which I cannot even believe is a recommendation as it removes what gives drywall much of its structural integrity).
Another option, depending on how much experience you have, is to put up a 1/4 inch layer of new drywall over the existing textured wall. You'd want to remove baseboards if you went this route and you'd also want to verify that you could remove door casings and put them back on without creating a large gap between the door frame and the casing. Or you could just run the 1/4 inch drywall up to the door casing and lose 1/4 inch of width.
I doubt you'll be able to remove a paint texture. It shouldn't be that difficult to apply a thin skim coat over it to smooth it out. If you want to replicate the texture we should be able to help but a pic showing the texture would be helpful.
As a Real Estate Broker, I can say that textured paint is usually associated with some underlying irregularity that is being hidden.
When you succeed in removing it, you may know why they originally chose to apply it.
