Cement board fasteners
Old 06-30-17, 06:07 PM
B
Looking for the best screws to use in cement board tub surround tile backer.
Should I find some corrosion proof?
Old 06-30-17, 07:49 PM
XSleeper's Avatar
Received 1,840 Upvotes on 1,655 Posts
Hardibacker screws are coated.
Old 07-01-17, 06:32 AM
Received 128 Upvotes on 113 Posts
A whole lot faster and easier, cheaper to use Galv, roofing nails.
Far easier to get them to sit flush then the screws.
Old 07-01-17, 07:34 AM
W
Received 63 Upvotes on 55 Posts
The tile adhesive will fill the voids.
Old 07-01-17, 08:18 AM
czizzi's Avatar
Use the correct screws for the type of backerboard you are using. IMO, 1/2" Durock or Permabase is easiest to use on walls. It also will sit flush to the adjacent drywall so you can make a nice transition. I hang mine initially with roofing nails and then go back and screw it off. Backer screws have heads that are designed to grip the board. Other types of nails will pull through the backer and break the surface and not have any holding power.
