Bathroom ceiling
Old 08-16-17, 09:19 PM
H
Bathroom ceiling
I picked up old fir that was used outside. Im thinking of installing it onto the strapping to make a new bathroom ceiling after removing damaged acoustical tile.
I assume I should add plastic sheeting as a moisture barrier first.
Add some poly to resist moisture.
What type of nail or screw should I use?
Anything else?
Old 08-17-17, 05:54 AM
That seems to be a lot of weight. I would probably use decking screws if I attempted it at all.
Old 08-17-17, 06:21 AM
Received 383 Votes on 339 Posts
I'd be concerned about mold/mildew installing those used exterior boards in a bath rm.
Old 08-17-17, 08:16 AM
Received 98 Votes on 86 Posts
I wouldn't do it but if I did I'd be sealing all six sides of the wood first, installing with deck screws and then adding at least another coat of poly after installation.
