Durock vs DensShield
Old 02-07-18, 08:41 PM
K
I'm installing an acrylic shower base and would like some advice on the backer board around the shower. Of course I'll be tiling it, but I would like to know if I should install Durock or DensShield (both are available here). From what I've read, it looks like they are both suitable. DensShield is easier to work with (basically just drywall with a water proof membrane), whereas the Durock is basically a cement board so it's a bit harder to work with. I would appreciate your advice.
Thanks !
Old 02-07-18, 08:47 PM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
DensShield is easier to work with imo, and it is a smoother surface. If you can get the 4x8 sheets that helps too.
Old 02-07-18, 09:05 PM
K
Thanks XSleeper ! If I go with DensShield do I need to coat it with Redgard ? Also what should I use for joints (based on reading the posts, it sounds like mesh tape and mortar ?)...
Old 02-07-18, 09:20 PM
XSleeper's Avatar
https://www.google.com/url?sa=t&sour...yZ_YxfcFzl-Iwx
Yes, Redgard over everything. Alkali resistant fiberglass tape and mortar joints just like cement board.
Old 02-07-18, 10:50 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
If you want a truly waterproof shower, one that you never, ever, have to worry about leaks for get the Redguard and go with Prova or Ditra membrane.
