ceiling corner cracks on painted wall
Old 02-24-18, 10:58 AM
H
Good day, I bought it house last June and the owner had a new paint job all house. The house is 20 years old.
I just found last week there are a few cracks at the point where the ceiling and the wall meet.
I found the cracks in all 3 rooms. Not the living area nor basement.
I thought it could be a simply fix or just little patch up job, but someone told me it could be a roof problem
since it is a 20yrs old original roof.
When I bought the house, the inspector told me that the roof needs to be replaced soon, which I am going
to replace the roof, windows, and rear fence at the same time this summer time.
Please advise me how to fix it. Can I DIY it?
thanks.
Old 02-24-18, 11:03 AM
Tolyn Ironhand's Avatar
Received 705 Upvotes on 598 Posts
Where two planes meet is where the most movement happens in a building. Your cracks appear very minor to me and is just likely do to minor movement between the wall and ceiling. I would just get a little painters caulk and fill in the cracks wiping away the extra with a damp cloth.
Old 02-24-18, 01:38 PM
Received 125 Upvotes on 110 Posts
Looks like a bad tape job to me.
Old 02-25-18, 02:08 AM
Received 753 Upvotes on 658 Posts
Caulk should do a decent job except for the 3rd pic which shows the tape coming loose. Even so caulking it would be less invasive there than removing/replacing the tape, finishing and touching up the texture.
Old 02-25-18, 09:40 AM
H
So, basically it's a minor cosmetic issue?
if so, can I do it, fix it, patch it myself?
I don' have any hands experience with painting/patching wall.
Old 02-25-18, 09:44 AM
Get a tube of acrylic latex caulk and apply it on the cracks. Have a damp/wet rag handy to remove any errant caulk and clean your fingers. While the loose tape should be removed and redone, you could smear just a little caulk into the void and call it good enough.
Old 02-25-18, 05:37 PM
H
I am sorry it might be a stupid question, but are we talking about drywall joint tape? I should remove the old tape and re do the tape, compound, and paint again to fix It?
how about ceiling corner trim or moulding?
Old 02-26-18, 02:43 AM
Yes, it's paper drywall tape that is folded and mudded into place on the corners. That type of repairs involves removing the tape, scraping down the texture next to the tape, retaping, 2-3 coats of joint compound and then retexturing to match. That is why I suggested just caulking it.
