Help!!!!!
Old 03-03-18, 07:10 AM
Angry Help!!!!!
Ok I hope I get some ideas. I am kinda new to DIY. I am redoing my living room & dining room My problem is insulation right now I have 1/2 inch boards on my walls,so the only option I have is foam board for insulation that only has a r value of 3. Should I take them down and put up 2x4 and use a proper insulation??
I live in a brick row home end unit, so the left side of my house there is nothing. Just wondering if it would be beneficial to put up 2x4 or is there a really good 1/2 inch insulation that I don't know about? Thanks in advance ohh one more thing I live in baltimore where the recommended r value is 38, and there was no insulation the wall when I took it down.
Old 03-03-18, 07:13 AM
Received 759 Upvotes on 664 Posts
Welcome to the forums!
A stud wall in front of the brick will allow you better insulation.
How is your electric run on that wall?
Old 03-03-18, 07:17 AM
it just has 2 outlets and the box is kinda dug into the brick
Old 03-03-18, 07:20 AM
also what about my windows? how can I put up a 2x4 wall? would I just add wood to the frame??
Is this double brick with the electric wires run in the void between the 2 rows of brick? about how old is the bldg?
You'd frame out around the windows, would give you a deeper window stool/seat.
Old 03-03-18, 07:27 AM
yeah its double brick and the wire is behind the boards.
