yes. the front side is lighter in color and the long edges
are beveled in for taping. the back side is flat and goes
against the wall. any writing on the drywall will also be
on the back side.
Hello
We've added a room to our home. The room has drywall on 3 other walls, except the existing brick wall from the house, which now become part of the room walls. I want to put plaster, make it smooth and then paint it to match the other 3 walls. Is it a good approach to transform the brick wall? Any ideas/suggestion?
A friend at work suggested that I space 2x2 lumbers on the brick wall, and screw drywall to the lumbers. Well, I'm not so excited about drilling into brick. What do you think of this method?
Thanks
HalRead More
Help me! I just removed some seriously old wallpaper from my hallway. It was actually falling off on its own. I want to paint these walls, but I have a lot of areas where the drywall was ripped, not enough to make an actual hole, but enough to look and feel rough, and show the brown fuzzy paper through what was apparently a coat of paint under this walllpaper. How do I repair these rough and fuzzy patches of drywall??????Read More
