Dimple in drywall ceiling
Old 06-22-18, 12:09 PM
C
Hi,
Spotted a couple of dimples in my drywall ceiling, and trying to get an idea if this is something I should try to fix or if I need to call a drywall contractor. There is attic space over this ceiling -- no apparent signs of water damage that I can see. The drywall feels solid to the touch -- no crumbling or give to the drywall itself. Also, not seeing a super obvious sag, although depending on lighting and time of day, I can spot a few seams (house is 40+ years old).
Tried putting a little pressure on the ceiling near the dimples I can see -- for most of them, no give or movement when I press, but for a couple, I can feel a small bit of movement, and looks like if I pushed hard enough, I could get the nail head to poke through.
Looking for advice on best way to address where there is movement -- should I just add a couple of drywall screws to secure and patch things up, or am I better off calling a drywall contractor?
Thanks for any help.
Old 06-22-18, 01:01 PM
Received 753 Upvotes on 658 Posts
Where you can press up - add a screw or two. Pressing with the flat side of a 2x4 or piece of plywood is better than using your hand as it spreads the pressure over a larger area. The screw head will need a little mud and texture to finish the repair.
Most drywall finishers would consider that job too small to bother with. You could hire a handyman ..... but it's not a difficult repair if you want to diy.
Old 06-22-18, 03:34 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
Typ nail pop, sort of. just dab some compound on the spot, prime and repaint.
Old 06-22-18, 03:43 PM
Received 3,480 Upvotes on 3,125 Posts
You could just go ahead and compound over those spots but adding a screw on either side of it ensures the pop won't return.
Old 06-22-18, 04:05 PM
C
Great -- thank you all for the responses...appreciate the peace of mind knowing it's as small as I was hoping.
