Load Bearing Wall
Old 06-25-18, 08:31 PM
D
Received 1 Upvote on 1 Post
Load Bearing Wall
We have a wall in one of our bedrooms that we want to take out but it is a load bearing wall. It was the front wall of a closet, which was about 12’ long by 4’ wide. The bedroom is upstairs so there is nothing above it, but there are ceiling joists that tie into the roof. I know it is load bearing because the joists in the attic that run perpendicular to the wall do not run the entire length of the room - one goes from the front of the room toward the back and ends right over this wall and the other joists are shorter and go from the back of the room to just over this wall (so those are only about 6’ in length. We want to remove the closet wall (we built a new closet space into the attic that is bigger) but I don’t know what size beam and studs I need to put in it’s place to carry the weight of that span. Any help would be appreciated.
Old 06-25-18, 08:49 PM
Received 1,197 Upvotes on 1,152 Posts
This usually requires an on-site engineer, not an online forum. Sorry, not what you wanted to hear, I know.
Old 06-26-18, 12:01 AM
D
No worries - I didn’t know if there was a general rule of thumb out there that said if you have a span X feet long, you need a beam at least Y inches thick or anything like that.
Old 06-26-18, 12:40 AM
Yeah, it would be nice if it was that simple.
