Kitchen/Living room picture window wall
The part above the kneewall, definitely. The part over the doorway... "you would think so", but it would be helpful to double check in the attic that no joists sit on top of that small section and happen to be half lapped above it, just to make sure. Also check below the walls to see what might be running up into them.
If there is any electrical or plumbing in the wall you would like to remove, consider where it will go if you remove the wall it's currently in. You can't just clip wires then cap and conceal them in the floor or ceiling.
The two outlets go down in the basement and hit a junction box with other lines going in and out. So those can be removed with no issues. I will double check on the hoist above the small section
