Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Any idea on how to fix this stain? or whatever it is?
Old 11-15-18, 04:08 AM
A
Exclamation Any idea on how to fix this stain? or whatever it is?
Hi beautiful people, can you give me an advice on how to clean that, I need to move as a result I need to give my room.
Thank you.
Old 11-15-18, 04:16 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Looks like mildew. Is there a roof leak in that area?
Old 11-15-18, 04:29 AM
Received 754 Upvotes on 659 Posts
Fix the leak first, then remove the mildew/mold. If it washes off and the drywall is solid you can prime and paint otherwise that section of drywall should be removed.
btw - welcome to the forums!
Old 11-15-18, 04:41 AM
P
Received 1,849 Upvotes on 1,655 Posts
If you leave the existing sheetrock in place first paint it with a stain blocking oil based primer such as Zinser 123 or Kilz. That will stop the stain from penetrating through the final water based latex paint.
Old 11-15-18, 04:59 AM
If the mildew isn't washed off first you run the risk of it coming thru the primer [not right away] There are mold killing primers although I've not used them.
