Fixing Some Drywall
Received 0 Votes
Fixing Some Drywall
http://share.icloud.com/photos/0QLbn...wBna4cWEi75wYg
Here is a pic, not sure if either will appear or if the link will work, but hopefully.
I did some electrical work and had to cut a small section of drywall from the ceiling and top portion of wall. I kept the sections that were cut out and put the small squares back their respectful spots. Where the two sections meet at the top of the wall and ceiling (where they butt together), I am wondering if I need to tape and mud or just mud when I repair the drywall?
Received 0 Votes
You should install some wood backing as mentioned earlier. Then use mesh tape and setting compound on all the joints.
You may have a problem matching the texture of the existing wall. Good luck.
