Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
How to drywall and caulk? Step Sequence
Old 01-02-19, 03:54 AM
Yasenarr's Avatar
Ok, so this is an easy general question - that I can't find the exact sequence of steps for drywalling and caulking a single frame 2 leaf wall. Let's just focus on the one leaf... what are the steps once the wall is framed, electrical is run etc.?
Assume the inner leaf will NOT be on RC and will just consist of a layer of 1/2" and 5/8" drywall screwed to the studs.
Where do I caulk? Do I start caulking the perimeter of the wall before hanging any drywall https://mechanicguides.com/sanders-for-drywall/ ? Do I then caulk around each sheet of drywall? and then squish the next piece of drywall to the other already hung piece of drywall repeating this til all drywall for the 1st layer is done?
Or forget that - Do I just run some caulk over the joint between each piece of drywall? Then how does the drywall joint compound and tape work on top of that?
Or is it just use acoustical caulk wherever there is a small gap (along the floor and ceiling perimeter) and just drywall as normal... hang drywall, tape, joint compound, screw next layer with 1/4" gap from the floor and repeat?
I just can't find the clearest instructions on the actual steps of hanging the drywall and doing caulking for a studio type wall...
I do not want to forget any important steps...
thanks,
Chris.
Old 01-02-19, 04:38 AM
Received 786 Upvotes on 689 Posts
Welcome to the forums Chris!
Not sure what your intended purpose for the caulk is ??
The drywall tape seals the drywall between sheets including the corners. A bead of caulk could be run along the bottom plate prior to installing the drywall to air seal any gap there - not sure it's needed.
