New dry wall installation
Old 03-10-19, 08:30 PM
C
Hi all, I need help
Im looking to repair the walls in a rental. It has wood panel around the kitchen and I want to remove the panel, the tile behind it and replace with new dry wall. (Its plaster wall behind it) I’m trying to do this without removing the cabinets. Take a look at the pics attached and let me know if you think it could be done that way
Old 03-10-19, 08:40 PM
Received 1,197 Upvotes on 1,152 Posts
Please refer to the sticky post at the top of the thread for picture instructions.
Old 03-11-19, 02:45 AM
Received 753 Upvotes on 658 Posts
Welcome to the forums!
Most anything is possible although you'd have to cut the plaster next to the cabinets. What about the wall between the top and bottom cabinets? If you don't remove all the plaster you'd likely need to fur out the walls so the drywall will meet up with the remaining plaster. Cabinets shouldn't be difficult to remove and that would make more the easiest wall replacement.
How to insert pictures.
Old 03-11-19, 04:52 AM
P
Received 1,840 Upvotes on 1,647 Posts
I would take down the cabinets. Trying to cut around them will be slow and tedious and with a good chance you'll scratch them. With the cabinets out of the way you can just rip down the plaster & lath without having to be careful.
Old 03-12-19, 07:10 PM
maarkr's Avatar
Received 18 Upvotes on 16 Posts
you will be so happy afterwards if you take everything out to the studs, then SR
