Cement board help.
Old 05-29-19, 02:07 PM
O
Cement board help.
Hello, I hung cement board all around my tub with a vapor barrier. I then hung an ABS plastic surround using Loctite Surround. I did not notice it was not for use on cement board. Am I completely screwed? It’s been 24 hours and it hasn’t fallen off.
Old 05-29-19, 02:12 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
Is it PL550? I don't see in the directions where it says not to go over cement board.
Old 05-29-19, 04:21 PM
czizzi's Avatar
Problem with cement board is that it is dusty and will not create in my opinion a long lasting strong bond.
Old 05-31-19, 08:27 AM
O
Loctite
I used Loctite tub and surround. I couldn’t find the liquid nails kind. Didn’t know about bleed through on the pl. guess I will just have to see if it falls down.
