Cross studs behind drywall
Old 08-25-19, 05:27 PM
A
Trying to wall mount a TV and also add a powerbridge to hide wires. I used a stud finder but it would give unreliable results i.e. it would show a stud at one place but if I moved the stud finder down it would show it some other place. Tried another stud finder - not much different. Fine. I think let me first do the powerbridge and when I cut out the drywall, it will be obvious where the studs are. I use both stud finders to find a spot near an existing outlet that both agree has no studs. Used a dry wall saw to cut through and just my luck - hit a stud. Not only that, they are cross or slanting. This is on a wall which has an exterior i.e. it is not an interior only wall. No wonder there were issues finding the studs. Any idea what these are and how to reliably find these?
Old 08-25-19, 06:24 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
The diagonal board is wind bracing. Slide a coat hanger into the wall to measure where the adjacent studs are. The will likely be to the left and right of your hole.
Azeem Feroz voted this post useful.
Old 08-26-19, 07:25 AM
A
Thanks a lot for the reply XSleeper! Will definitely try that. Is there usually just one of these for the wall? For the powerbridge, I am assuming you would recommend moving the hole I had for the power to another location - trying to avoid another hole where the wind bracing is.
Old 08-26-19, 07:45 AM
XSleeper's Avatar
Yeah you will need a different hole off to the side if you have wires to stuff back in the wall
