Drywall Questions
Old 01-30-20, 02:18 AM
P
Drywall Questions
I’m currently renovating a 1920’s duplex that will serve as rental property. For drywall, I will not be doing the work myself and instead using a contractor. Drywall will replace dilapidated plaster, which has already been completely removed, mostly in the ceilings. The specifications will be 5/8 inch drywall with 1 5/8 inch screws. The contractor has said I can use shorter screws 1 3/4 inch but will go with the longer screws. These specs meet local code. Although the code does not require it, I am wondering if it’s a good idea to use "fire-code" drywall (called Type X) instead of regular drywall. I’m more focused on weight on the stud system of the old building rather than cost as a consideration. Looking forward to your feedback. If you have any other thoughts i.e. on thickness and length of screws, I would also appreciate them.
Old 01-30-20, 02:32 AM
Received 759 Upvotes on 664 Posts
I would assume code would call for firerock between the units. Are you using 5/8" everywhere?
Old 01-30-20, 07:46 AM
Marq1's Avatar
Received 1,142 Upvotes on 1,035 Posts
Unless it's a fire brake wall/ceiling then you dont need 5/8 or special drywall.
If you want to save weight go with 1/2"
Old 01-30-20, 11:52 AM
Received 1,198 Upvotes on 1,153 Posts
Am I missing something? 1 3/4" is a longer screw than 1 5/8".
Old 01-30-20, 01:08 PM
I was wondering the same thing, I assume it was a mis type ??
Old 01-31-20, 06:21 AM
P
The walls between the units will not be replaced. Yes 5/8 everywhere and you folks are right will use 1 5/8 not 1 3/4. Is all this OK?
Old 01-31-20, 09:59 PM
1 5/8" will put 1" of screw into the stud, this is fine.
Old 02-01-20, 08:06 PM
Received 125 Upvotes on 110 Posts
The only place 5/8 is needed is between the units and on the ceiling.
marksr voted this post useful.
Old 02-02-20, 05:25 AM
Z
Received 372 Upvotes on 332 Posts
I would use 1/2" drywall everywhere other than where firecode 5/8" is required. No need to add the extra cost. I'd rather spend that extra couple hundred $$ on something that someone will actually see.
