TV Divider Wall
Old 02-06-20, 12:02 AM
K
TV Divider Wall
I want to build a room divider as thin as possible and attach a tv to it. Looking for ideas to stabilize the wall as above is a boxed in duct work, below is hardwood floor and I dont want the wall to span the full width of the room. One suggestion was metal pipe feet but looking for other options.
Old 02-06-20, 12:19 AM
XSleeper's Avatar
Received 1,745 Upvotes on 1,569 Posts
If it's going to be semi permanent, build it like any other wall. Top and bottom plate... Glue the top plate with construction adhesive since you shouldn't really screw to the duct.
